3dsmax 6 recompiles
Hi all,
We’ve uploaded recompiles for 3dsmax 6 of all VRay versions (Free, Demo, Advanced, Basic, NFR, Educational). There are no new features really, these are just recompiles (still, customers using the Advanced version may want to download this build, since it seems that the old one was unstable). Distributed rendering is still not included - it will have to wait for the next major update. Bake3D is recompiled though.
http://www.vrayrender.com/download/
Photon mapping isn’t working for me in this new version. It doesn’t crash Max on me like the previous one did though.
Which VRay version is that? It does work in the Advanced build, just checked that…
It’s VRayInstall_Adv10903n60.exe. Seems to be working now, but not as good as direct computation. Even if I pump the spotlight’s multiplier in VRay properties to 700,000 (though I can’t really say I understand that feature).
Still having the same problem with displacement, if there is more than one object with displacement applied to it I get an unhandled exception error.
Tony
TonyDon’t instance your objects, copy them and it should be fine.
The objects are not instanced. Each is a seperate ceiling polygon with a tile texture applied with .375 inch 3d displacement applied.
I just tried it with a simple scene with two planes and displacement applied as before and it worked , but if I go to my large scene it errors.
I went through each object and the only time it errors is if I have both objects with displacement on at the same time.
I even remodeled the ceilings and reapplied the materials, I still get the error.
I’m doing something wrong, I just can’t figure out what it is, I guess.
Thanks for your help, vlado.
Tony
Look at your memory usage; if you are using 3d displacement, choose a different acceleration method or reduce the maximum amount of triangles for the quad-tree accelerator.
Does the recompile for bake3d include any new features?
Does the recompile for bake3d include any new features?Nope. It’s just a recompile.
hello, bake3d come with vray or I have to buy it apart? :roll:
it comes with vray
hello chaotic…any plans with DR and max 6 ? i´m planning another project and it would great to know when DR with max 6 is working ???
yeah Pease… got some big walkthroughs to do very soon … we need it working… Please :frowning:
walkthroughs? I was under the impression that DR was NOT intended for anims and using regular backburner/netrender (or whatever its called) was the best approach for animations.
Percy
Distributed Rendering not ment for animations ?.. then what is it ment for?
for biiiiiiiig stills. but you can also do animations now with it…it´s possible, but percy is right..for animations you can also wqork with backburner
and that works ok with a saved IRR map ?
Yep, works great. Just need to cal’c the map on one box first , incremental, every 10-30 nth frames.
cool … ive just always used vray DR didnt even cross my mind to use Backburner :sweat_smile:
