hey,
i was playing with 3dsmax background and i have this problem, 3dsmax doesn’t show map in viewport…
(look at printscreen)
this problem is so dumb, i cant find answer in google.. anybody encounter that problem?
Try to turn exposure control off - it has no use in Corona anyway.
nothing changes ![]()
It could be lost bitmap path or some problem with graphic driver. Try to switch from nitrous to directx and back again.
Does ANY bitmap/map work for you as bg? Have you tried removing the Ł from file name?
thanks, changing drivers, back and forward worked out.
