3dsMax - Graphical Representation of Map Parameters
In this overview you will see how each parameter in a map effect the output, it is represented in a Photoshop styled curve.
I take no responsibility if you get dizzy and puke.
This is how the overview is organized.
  • Map
  • Parameter
  • Two animated curves moving in 10 or 0.1 increments, depending on the parameter.
    The first curve is minus and the second curve is plus.
I will add more in the future, feel free to request.
ColorCorrection
Standard - Brightness
Standard - Contrast
Advanced - Gain
Advanced - Gamma/Contrast
Advanced - Pivot (This parameter will move the gamma endpoint)
Advanced - Lift/Offset
Output
Output Amount
This parameter behaves weird on the curve, Lord Ondra has the answer:
Ondra: Output Amount differs from RGB level in that the first one will also influence gamma.
RGB Offset
RGB Level
RGB Multiply
Output Amount (White to Black)
VRayHDRI
Overall Mult
Inverse Gamma (This is the same as “Advanced - Gamma/Contrast” in the “ColorCorrection” Map
Note: Output Amount differs from RGB level in that the first one will also influence gamma, second one will not.
Great reference!! Thanks
So what’s the next step? The same thing in MS Paint?
OMG that ColorCorrection - Standard - Contrast curve looks like a typical you-know-who-company product…
Good Luck
The contrast is literally retarded, who ever thought that was a smart idea ?
The only parameter from CC that works is saturation and gamma. So much for its robustness.
