3dsmax loading image sequence does not load all frames
Is there a reason this is happening ? Its not a memory issue as I have 24gb on my system and its a very simple scene.
Are you sure there isn’t one frame missing or mistake in naming number?
I don’t think so as all the frames were output from aftereffects with sequential names..I decided to use avi instead now though as I haven’t got time to work out what was wrong with this method.
do you try to load the images in max ramplayer? there was a memory thing at 2 gig. the ram player just stops loading after that limit..
buy pdplayer!!! ramplayer is terrible
Well, that’s one solution :slight_smile: But I don’t want to have to fork out money for something I only use very rarely…plus it should work, and if it’s not, then there will more than likely be a way around it :slight_smile:
It seems the format needs to be quite specific for max and ram player to be able to read the sequence correctly. Check this out if you are interested: LINK
Make sure you that aren’t just telling Max to open an incomplete .IFL file. Select the type of file you specifically want to open and have it create a .
