does 3dsmax noise works in conjunction witth vray uvw randomizer?
The VRayUVWRandomizer requires a “Mapping source” input, which the 3ds Max native noise map does not have. You may bake the noise tex (right-click in ME>Render Map) and use the image through a VRayBitmap if you wish.
but is it possible to implement as in corona?
The CoronaUVWRandomizer works in a different matter (as an intermediary node), hence why procedural textures work with it. I’ll mention the suggestion to our developers and we’ll see if we can implement such a functionality in the VRayUVWRandomizer too.
thank you aleksandar, that would be great
I echo that this is something I’ve often wished for as I use the noise map ALL the time. Please mention it to dev team!
You could add the idea to the Portal so people can vote on it.
done! feel free to vote good people ![]()
thanks a mil - I started watching that but ran out of time. Will definitely finish - his tuts are brilliant
