is there anyway i can render animation with vantage @ 3dsmax, also using vantage scene setting. coz i have everything set, but i couldnt apply those when rendering animation. Looking for help~
Hi pun_lawrence,
What changes have you made inside Vantage and saved in the .vantage file? When in Live link or when using āRender animation with Chaos Vantageā it is advised to only make changes to fog, post and render settings as those will not be discarded when rendering the animation. If you set your lighting or camera settings(exposure, FoV, DoF, etc) they will be discarded and reset to the ones in 3ds Max. If you use a saved .vantage scene and you want to render an animation then you would first start Live link, load the .vantage file and then start the animation.
Alexander
