3gb Switch?
Can this be resolved by the 3gb switch? Im on a school computer and dont know if i should mess with it.
https://jshare.johnshopkins.edu/dfernan5/problem.jpg?uniq=k7ej5u
thanks!
Possibly.
Reducing your rendering size or using Render Strips can help as well.
read through the excessive memory section at Chaos: Industry-leading design and visualization software if you haven’t yet also
thanks guys, i just lowered some of the settings in vray system, and its working fine!
I have another completley unrelated question. Is there any way to only render a pass with reflections and masks and nothing else, so i can composite it onto some windows? thanks!
use the vray frame buffer and set up the buffer channels for the passes you want.
