Hey guys,
I have a scene with 4 simulators which I would like to connect with one Ocean. Is it Possible?
My setup:
Sim01 has Ocean mesh “On” and as you can see on the img the blending with the ocean is fine
Sims02,03,04 have Cap mesh “On” but they have NO blending with the ocean from Sim01, even though their initial fill ups and Ocean levels values are also equal to the ones in Sim01.
The way I have connected them is by using interacion in Sim02,03,04 where I made Include lists for each one and picked the Sim01 and of course the objects they must interact with(this case the faucets). (not sure whether that’s the correct way of connecting them…) check example below
If you guys by any chance suggest creating one common simulator for all 4 sims, I had already tried that. But simply the scene got too heavy to work with, where this setup with 4 separate simulators is much lighter!
Anyone?
Thanks!
