When outputting render elements with Png’s set to 48 trillion colours, the files are getting corrupted.
I have moved over to 32 bit tiff’s for now.
Just out of curiosity, did you tried EXR’s? It’s a great image format, and really powerful ![]()
Cheers.
I have, the file sizes get me in trouble a little with file space at work ![]()
Thinking I might need to go EXR
…having a lot of issues with Tiff’s as well and Corona.
Half the time my tiffs save greyscale.
Corona does not handle the saving, 3dsmax does - so it is very probable that the problem is elsewhere. Does this format works for other renderers?
Yes, I had the same problem with Corona.
With V-Ray, no problem for example.
Just checked, elements seem to save fine with both 1.0 and DB09.06, tif and png.
There is one curiosity, world position pass, the only difference between these two was changed file extension.
worldp.zip (174 KB)
I must have messed something with file types. So it seems these artifacts on world position pop up or not, randomly, but I never noticed them when saving pngs. This time I managed to save corrupted pngs (attachment), but was never able to recreate this again. Hard one. ![]()
corrupted-png.zip (1.8 MB)
in what scenarios does this happen? When saving via setting output path in render settings “common” and hitting render, or directly from FB? Does this happen only when DR is involved?
I did some blind changes that could help. Let me know if the problem happens after todays daily build
