One of those files
CoronaUtils2013
Corona2013
Instantly crash max on start. I cant test corona ![]()
max 2014 64b win 7 64
One of those files
CoronaUtils2013
Corona2013
did the installer finish without any errors or warnings?
Yes, is the 2013 file meant to be in 2014 folder?
ok, what sort of crash do you get? Some error message? Can you printscreen it?
Ill do my best. It disapears very quickly and then I have max crash report ![]()
hmm… does the benchmark scene work for you? - Corona Alpha4 Benchmark scene - Corona for 3ds Max :: General - Chaos Forum
Yea works.
Its worth mentioning that that error pops up on 3ds max start. Not when I render. I cant even start max ![]()
yes, I’ve figured. It probably clashes with some other plugin you have installer. You can try for example extracting the files from installer (there is option for it) and copying them manually, making sure you copy over all the files, but I am not sure it will help
I think I only have vray demo or something like that. Strange!
Will see if I can somehow re-install max…
Thanks for help !
I have exactly the same error.
managed to solve the issue by installing alpha v4, then reinstalling v5, deleting all the installed files, then reinstalling v5 again!
i take it back. same issue. cant find a fix.
my guess is still clashing libraries. The next release will include custom-named libs, so maybe it will solve the problem. Try it in a month when it is out.
