64 threads limit
Right now if you try to render with a pair of e5-2699V3 (72 threads), corona would use only 50% of the CPU. It renders fine with HT off, but it means loosing 15-20% of speed.
Is it possible to make Corona to use more than 64 threads? Cinebench works fine with all 72 threads. Chaosgroup seems to have resolved the issue in the latest builds of Vray.
Thank you.
There was discussion about this problem while ago. You may want to read this: Corona not using all cores ? - Corona for 3ds Max :: General - Chaos Forum
Thanks. Yes, I read that post. That’s workaround, not a solution.
Also, running a second DR server on a render node won’t work.
Latest Vray builds work with more than 64 threads, they fixed it since than.
Should be fixed in todays daily, can you give it a try?
Ondra, thanks for fixing it.
I installed 1.3 RC5 - works great so far. All 72 threads are at 100%
About 25% performance increase. My test scene gives me 20M rays/s, vs 15M with HT off.
can you share the test scene??
Sorry, I can’t - client had me sign NDA. Its just a current work scene, not a dedicated test - if thats what you were asking.
