64 to 32 bit???
I have some friends that are on a bit of a pickle, they have a 64 bitt Max-Vray model that they need to run an animation off but the farm in the office is running on 32 bit.
Is there a way to “downgrade” an existing file from 64 to 32???
Many thanks in advance
They are using max 9 and vray 1.5 r3
thanks!!!
have they even tried yet? It shouldn’t be a problem afaik.
The files themselves are not specific to 32 or 64bit.
So they will be able to open it just fine. Assuming they have the same max version and plugins..etc..etc..
you can also choose to submit the job as 32 or 64 when you submit the job with backburner. It’s in the advanced dialog when you are submitting the job.
Send the job 32bit and it will render on their 32bit farm.
