I could not get our farm to work with this release got connection errors and no license issues. It worked some yesterday but would crash Max at render completion
I have had to revert back to the December release
I also had issues with render farm computers (Deadline) after I installed few updates but I was able to solve them. I had updated plugins to new versions - V-Ray v7.30.02, PhoenixFD v5.25.00, TyFlow 2.005, and ForestPack v9.40. And I updated these plugins on my workstation as well. Workstation worked fine. Then I tried to render on render farm and got errors on all render farm computers including my workstation as render node. My computers on render farm were crashing before render. I checked all computers and found that problem Microsoft Visual C++ 2015 - 2022 v14.44.xxxx was installed on render node computers. Even if I uninstalled it some time ago. So, I uninstalled MVC++ 2015-2022 again, and installed Microsoft Visual C++ v14.50.35719. After that all computers except one worked fine. For the last problem computer I had to reinstall Deadline Client. All computers work fine now.
My department also had issues with DR2 on our renderfarm. All of our jobs got stuck on “preparing global light manager”. Everything worked fine after installing the 7.3 DR1 version
Mine issue not solve after installed DR1, I have upload a screen record video: Submission ID# NKSS-W4GY
You mentioned you solved your issue. Is this still the case?
ya, after I have posted this message, i sovled the problem.
Love the new vray update, BUT unfortunately i have to look up for a thread like this.
I’m also encountering some instability with DR2 i guess. (3ds Max 2026)
Interestingly there different issues coming up, mainly when render finishes.
One time, i get this old known viewport not refreshing anymore (but you can still save the file) had this before a few years ago
One time 3ds max is crashing completely
One time whole max is freezing (can’t save anymore)
Just want to get a feeling for: some more people having these issues? Or is it just my setup to check?
I recently had to install Visual Studio 2022 & Cuda Toolkit because of Lichtfeld Studio.
Could that be interfering?
Update:
Seems installing the latest nightly did the trick! *yeay*
Same issue here on all workstations - constant crashes when renderings complete. I’ll try the suggested hotfix version, which I hope fixes the issues.
I was having this issue on the previous DR2 and @hermit.crab told me it was a bug due to having standard or corona materials in the scene. Clearing those materials out kept it from crashing. He said it was on their to do list a month ago it would be unfortunate if a bug like that made it into the polished 7.3 version somehow… Anyway, might want to try that.
All the material crashes (Physical, OpenPBR, CoronaLegacy) with DR2 should be fixed in the latest nightly (V-Ray 7.30.50.33550), tested, and confirmed. Please, test it out.
Great! I’ll test it out!
These fixes are included in our Stable builds, and soon they will be included in a hotfix.
The crashes are fixed and implemented in the latest hotfix.
Just installed the latest relaese. Appreciate the update. Unfortuneately there is still no light cache preview with DR enabled. Is this by design or something to be fixed? No mouse follow either. The local machine shows the PC name in the render bucket, but the DR buckets show an I.P. number
Same here.
The hotfix handled the most severe issues only (crashes).We’ll get to those issues eventually.
Sadly I have to report the same issue.
High-res render sent via DR2 are stopping at “Preparing Global light manager”.
Max 2027, V-Ray 7.4.04
Check if the DR nodes have cloud licensing active. If yes, switch to the local license server and try again.
