Hi folks,
it is possible to make 8bit EXR from other 8bit formats ( like jpg.. ) ? I can save to EXR only if it is in 16/32bit range.
if it`s possible, then it would be great to use tile-ability with mipmaps for 8bit textures without redundant data ( if 8bit palette is enough )
Only exr, hdr and tiff for floating point unfortunately - I don’t think there’s an 8 bit version since if you made any major exposure / colour correction you’d start to get really bad banding in the images. Here’s a page that has a few more details - High Dynamic Range (HDR) Images FAQ - About Dynamic Range, Tone Mapping and HDR Merge for Photography
thanks, jconell, it seems that the vray support of tile-able exr is quite useless for largescale textures, for example making 32/16bit 20k X 20k px texture is overkill
or is there another workaround how to use large bitmaps like in mr .map format ?
It is enough to simply turn on the bitmap pager in 3ds Max - it will automaticallly take care of splitting large textures to chunks and paging them out to disk. This works regardless of the texture file format.
