8gb .vrimg file
So we got a task to render 25k image and my first thought is to render in vrimg format. Currently it is rendering and i have questions about next thing to do. In the exit we have an vrimg file of about 8gb thick. Will vrimg2exr handle such big file ? Or i will need to load it into 3dsmax vray framebuffer and save from there ? Also i am curious if i can open partially rendered vrimg to check what’s inside ? It is finished now for 93%. Currently i am trying to open it in vrayframebuffer but 3dsmax just eats all the 60gb of memory in 5 seconds and thats all ! :slight_smile:
Thanks.
Actually it went up to 20gb now
How big is your render and how many render elements do you have in it?
It is 25000x16666 and i have pretty much of elements. Well render is finished (24gb vrimg file) and i tried couple of standard tools and methods , like opening it in 3dsmax and converting with vrimg2exr tool just by running it with GUI - nothing worked. What worked is running vrim2exr via command line with -buffersize and -separatechannels keys (i think i spelled that correctly) , and it started extracting files just fine.
Yeah I would render to separate files for elements :slight_smile:
vrimg2exr will generally work fine, but as you find out you might need to adjust the buffer size and ultimately write each channel to a separate exr.
Yeah that’s exactly what i did and that’s the only option to convert such big file. I have 64gb ram so i let vrimg2exr use 50 of it while separating each channel.
Just out of interest why are you rendering at such a big res? What’s the image being used for?
Well client said they would print it on a banner. I have no idea why they need it around 600 DPI. Well he asked - we are doing :slight_smile:
Ha, fair enough. As long as they’re paying for it! :wink:
