A classic villa model rendering
That wet floor is from enscape?
About the channel map
Very cool lighting quality. The trees and the girl through it off. Those are elements you could have added in post, which would have added to the realism.
It’s a good idea to have the girl in the 3D scene and then replace it with a finetuned image in postproduction, because then you get more accurate reflections and shadows as if you would compose everything by hand.
Very nice quality like your other work!!!
One little issue - the girl is overbright and distracting. I would try to dim the texture, maybe at 70%. The skin is to bright, also the red cloth. At the first image it works better by larger shadows.
