a corner in italian restraunt
hi guys i post this image to say iam failure and loser man in vray and i`ll leave it and go with the default scanline with max
i cant reach any reality on my work , i cant config the rendering pro.
so what do u feel with this shit
hi image looks nice …
maybe a little over saturated due to high gi bounces..
also a few artifacts due to low Interp settings… try to keep them above 40and your clr thresh down to .3 or .25 and Nrm thresh down as well..
getting there.. :wink:
i think your problem might be more along the lines of putting in lights for the sake of making an area brighter without showing light sources. those large vray lights on the roof might be whats wrong. and they are messing the shadow on the plant because they are so wide. if you put florescents on the roof then that could explain them. but then you would need to change light color for them
