a dialog box for render slaves to target textures on a network
Hi all,
It be great to have some sort of dialog box for render slaves to re-direct or target the location of the textures/source images files on a network or hard drive.
currently the way of using say a terminal on a mac to try and target or redirect the slave to a particular location where the source images are to be found, be it either local or on a network, can prove quite fiddly. especially for less tech savvy users.
kind regards
ignuf
Well, we were thinking of implementing automatic texture distribution to the slaves, i.e. if a slave cannot find a texture map, it could request it from the main machine and store it on disk for further usage.
Hi Vlado,
thanks for the reply,
sounds cool ! would the process be completely automatic or would the user have some level of control over this ?
thanks Vlado
ignuf
There will be some control - at a minimum, the texture cache folder needs to be specified, as well as a limit of how long to keep the textures.
