A guide to reducing RAM usage in V-Ray
Thank you very much, Lele!! :slight_smile:
Best Regards,
SangHo Jung
That’s my weekend reading sorted - Lele I love you xx
Edit: So after reading through and looknig at our tiled maps you mention that vray is going to pick two sizes of map and interpolate between the two it makes sense for moving cameras so you can crossfade and not get any popping but I presume this interpolation is where the default softer look of the vray hdri map comes from?
For B Gotcha#3 “In Max, and likely in other DCCs, there is a convenient option to swap all bitmap loaders to VRayHDRI ones,…”
The last time I tried this it only swapped the texture maps. The other setting in the bitmap loader did not convert (like adjustments made in Coordinates and Output). I love the idea of converting whole scene but in practice I’ve found that you are better off using VRayHDRI from the start if you intend to use tiled textures.
Maybe this has been updated since last I brought it up…I’ll have to try it out again.
That said, thank you for the refresher Lele! Love seeing your posts.
Coordinates can be added in to the convertor but unfortunately output can’t as there’s no maxscript access to their values - you can modify some existing values but you’re not able to create any new points along the curve for example. Those rotters in autodesk!
Well poop :slight_smile: Thanks for the info!
Yeah, some things won’t work too well in a global conversion pass, you’re right: much better to start from VRayHDRIs, and do the conversion of the textures to tiled outside of the DCC.
The converters have an UI and allow for single or multiple files operations.
@joconnell I’m not sure i know what you’re talking about when you say “softer look”. Softer than what else? In theory, it should look very sharp, for that’s the whole idea behind doing the pre-processing of textures to generate atlases. If you have a test showing what you mean, it’d be very helpful (particularly if it turns out to be a bug, or something along the lines!).
@joconnell , there’s the obvious thing to be done to mip-mapped textures should they look blurry: in Max, lowering the Blur amount *slightly* will bias the choice of mips towards higher resolutions, which may look sharper (and ofc take up more RAM).
I’m told that the Elliptical filtering performance has been greatly improved in the latest nightlies (so it’ll come with the next SP), which ought to make it speed-viable as main filtering type, and add even more sharpness to the look of textures.
That’s great news Lele, I’ll have a look at that on monday if we can get the pipe folks to grab a new build. On the blurriness I think we go to 0.5 as our standard thing but I reckon it’s the interpolation you mention that I’m seeing - it’s going to make things look a bit misted / glowy!
Good read, always good to understand the mechanics behind the tools.
Many thanks!
this is great information. most of it has been bandied about on the forums at various times, but its very nice to get it all in one place, and from the horses mouth , so to speak. can i suggest this, and any other similar guides, are added to the help files?
1+
I’d love to see such threads more often. Very helpfull stuff.
mmmh, could be, but it could also have unintended consequences when, f.e., one renders over a farm.
It’d have to be tested, it’s a good idea, i think.
I can very likely come up with a pre/post render script set that one could use to do so, and that could work as proof of concept.
Thank you for the idea, i’ll take a look!
Great to hear Lele. Thanks for listening to (reading) our ideas.
Paul, I wonder how the native vrayinstancer object would also do? There’s definitely some room in forest for improvements! Clarisse is an utter beast of an engine but the pictures that come out suck at the minute :smile:
Assume they are optimised at best they can be living inside Max.
Forest may need the added ram to be able to create variants, vrayscatter may not.
Either way, scattering performance isn’t a topic in this thread, so it’d be nice to everyone else if you started a specific one.
Thanks Lele !
Really informative subject .
Hi Lele,
Thank you for a great article. It certanly did clarify many things regarding how voxels and tiled textures work. I just have a question related to Vray mesh export and “Export point cloud” option.
When it apeared for the first time I thought that it’s going to be one of the best Vray features ever for people who work with big scenes.
Unfortunatelly, I could never make it work. As I understand it is supposed to siplify geometry based on proximity from camera but in my case jump was always so sudden that it was useless to use in production. I experimented with hundrets point sizes but could never make it work.Is is unit or screen size based?
Can you explain how it works and how to fully use its benefits.
(BTW I’m on Vray 3.60.03, Max 2014)
regards
Zoran3d
The Point-Cloud option is an additional mesh abstraction, where the average properties of a cluster of faces will be written onto an oriented disk (the “point” in the name).
The structure is written directly into the Proxy, and as such isn’t aware of any camera parameter: the point size is expressed as percent of the object’s bounding box size.
Because of this, it’s not viable for automated use: the user needs to know what is being proxied, and how small the smallest detail to be represented is, compared to the size of the whole object.
The same applies when the proxy + point cloud representation get loaded: turning the PC display on won’t do anyone much good without tweaking the “Level Multiplier” option to properly suit that proxy’s distance to the observer.
So, say you have a very detailed hero tree in the many millions of polys range.
If you wanted to reuse it as an instance in a distant forest, as well, the point cloud option would help: you’d make a copy of the hero tree proxy, and for distant forest ones you’d turn on the Point representation, and set a suitably low LoD (by raising the “Level multiplier” parameter.).
What one cannot do is expect a point representation to smoothly interpolate across LoDs (do not, in other words, animate the “Level multiplier”: results won’t be pretty, but will be funky.), and much less so be too close to the original geometry.
While it could well be made identical to the source geometry (with a suitably tiny disc size) the exercise would defeat its own purpose by generating tons of new geometry as oriented disks, instead of triangles.
The proxy size on disk, its loading time, and the memory occupation wouldn’t then be optimal.
Lele,
Thanks for the quick reply.Nicely explained.Now things are more clear ( I think he he..)
-So, when exporting Lowest Level Point Size is the smallest particle/disk diametar expressed as a percentage of bounding box.
-Level multiplier is basically a trigger to switch on to PC, based on distance from camera.
-It’s an iterative process where one’d need to do export/import/test render untill “sweet spot” is found?
-If that is the case, would it be possible to code some sort of multiple lowest level point sizes (simmilar to mip-mapping) which’d give more flexibility when using PC? Something like: I want to export this mesh, 4 levels, from 0.02-2.0?
Cheers
Zoran3D
-) yes
-) No, the switch is above the spinner. Level multiplier changes the point size, so that at 1.0 is as it was saved, at 10.0 is ten times less pointd, and ten times bigger, and so on.
-) more or less but one needs just one save -to test- at low enough point scale, to then multiply the level up until it suits the scene. The one drawback is to maybe wanting to resave at higher point size/lower density to not burden the files on disk with needless detail
-) This could already be done exporting at 0.2, and then multiplying (Level multiplier) up to 10.
