I’ve tried using both the Gradient and Gradient Ramp maps in the Opacity map slot of the CoronaHairMtl, however neither seem to give me the result I want. The Falloff map also doesn’t seem to properly handle this. So with tht being said, having a map that can control the transparency of the hair strands like the VRayHairInfoText map could be very helpful in my opinion.
Thanks for the suggestion. We will look into this.
I understand this as a request to have the equivalent of VrayHairInfoTex in Corona, but on the other hand, can you explain what specific effect are you after? Maybe there is some way to achieve it already.
(Internal ID=436997236)
