A scenario exercise
Modify the next re-rendering
Hello zhangjx
in the scene no proxy no scatter?
The value is normal Ray/s 815,254 ?
Also in the above scenario the value Ray/s is 852,198
Flowers and grass are used in the corona comes scatter. Tree is a solid model.
Yes, thank you for your reply
In fact, overall no major changes just added a boat. Rendering time than before that a lot of long, just testing rendering speed and effectiveness, but also a lot of places not to my satisfaction. Because I was just learning corona, many places still do not understand. Thank you for your reply
Good morning zhangjix
Have you tried using the scatter as a box?
Checks the value of the primitive with Box and Solid model
Check box with the value Ray / s
  • comparison primitive -Ray/s-passes-time rendering
Thank
Raf
All is well, but 16 hours is a long time. Maybe you need to change the settings. I am also not yet fully understood
I’m sorry for my bad english, translated through Google come. Can you say more points you? I may be a novice to understand less, thank you for your reply.
Hello zhangjix
I don’t think it’s a good idea to use “HD cache” as primary and secondary solver. :smiley:
You should use “Path tracing” as primary solver and “HD Cache” as secondary for interior scenes.
In your scene it would be wiser to use “Path tracing” set as both primary and secondary solver.
