a small suggestion about the setting UI
I’ve heard some people say that VRay GPU’s IPR is not as responsive as Corona’s. Maybe they just don’t know how to adjust, and the parameters look too complex.
Would it be better to swap the places of these two? Left group for normal render, right group for IPR.
Maybe also put “Undersampling” to right bottom, and “Override depth” to left bottom.
Then these 3 parameters on the right hand side together control the IPR. Much easier to read and understand.
Hi, thank you for your suggestion. It is on our to-do list to improve the V-Ray Render Settings UI. This change and some others are going to be implemented.
