a tribute to tadao ando....
I was working on a virtually draft for a client.
task was to create a simple and minimalistic environment to show their
lightning products…
so I take some look at the drafts from tadao ando to create this scene.
here is the result
rendered with we vray-daylight system…
c&c are welcome
lightpixel
Looks great!! I’m a great fan of tadao Ando.
Maybe a little bit more of a fresher sky in the background (more blue)
its a bit gray now.But maybe this was your attention.
Great work!
I like the building !
But I find the image too dark. No lwf there ?
nice but I think Ando would have his concrete smooth and with the tie hole grouted
I think the render is a little to dark as mentioned above. The structure and modeling are very nice.
you can buy products that generate lightning? awesome!
:slight_smile:
hallo friends, thanks for the comments.
can give me some tips, to bright up the darken areas.
LWF…I read very much about it, but it´s a little bit to complicated for me :roll:
you can use “vray color mapping” in the vray render setting slot for the darker area.
Test “dark multiplier” to 1.1, 1.2, 1.3 until you have what you want.
But at first I think you must see the settings of your vray amera.
(up the iso, or down the shutter speed)
L.
