A very quick courtyard
This was requested towards the end of the day yesterday; rendered after I left.
What could have I done differently, if I had the time?
more subdivisions in the edge of the curved paving. PS people. variation in trees. planting. windows. doors?. clouds.
you asked.
Heh. Start over.
I’m going to peruse Turbo Squid for some PS people. Can anyone recommend any specific texture packs out there?
A little chamfering on the edges of those seats.
Lighting looks great.
Looks nice and natural, but I think the scale of the grass seems a little big for those people, either tile your displace map/diffuse maps, maybe lower the amount of disp.
Tom
A quick update for myself w the suggestions; thanks all. I hope to get back onto this project once it’s past the concept stage.
I would try to crop the frame on the right or rotate the camera target toward left in order to almost completley remove the useless gray building on the right (leave only its shadow on ground to suggest it); this should help opening your view
well in your latest image I must say, the ligthing looks just about perfect! The contrast between sunlight and shadow is in my opinion perfect! If only now somebody can fix the look of this VRSky!
Could you post your settings for your latest image please?
Nothing special. Daylight system with Vray Sun and sky, LWF workflow and plenty of post work in Photoshop; using a VrayPhysical camera with white balance would’ve probably helped with that.
Adaptive DMC 1/4 Clr thresh .007
Standard Max camera on this one
Color mapping Linear Multiply .05/.05/2.2 with Don’t affect colors ticked
Irr map set to medium then Custom Min/max -6/-1 HSph/Interp Samples 30/20
Light Cache 1000/.03
DMC Sampler Adaptive amount 1 and everything else to default
