Hi all,
A personal project I started some time ago:
The render settings aren´t final, as I try improve the materials as good as possible with my basic knowlegde of v-ray. Could anyone give me some suggestions regarding the leather material? On the picture below you see the material settings of the leather:
The new white background is much better to define the form and see what is going on. The depth of field is also excellent. However, I recommend you adjust your noise settings as it getting quite fuzzy.
As for the leather band, the texture looks very nice. But, the band seems to get too high & rounded as it wraps around the pin connector. It should end relatively flat and be parallel with the edge of the watch face. Remember, the band is folded over itself to make a loop for the pin. That folding makes it flat, not rounded.
