Not a big deal but may be an issue especially with spherical rendering.
The topmost row of the image (only one pixel wide) is brighter than the rest of the image. Not sure when and why it happens but I see it in every render here.
Can you post an example image? I dont see anything like this. But I had a problem with one column of pixels being too white after resizing an image in photoshop. The raw input image did not have this problem.
Sorry, no image right now. I was rendering against a map in screen mode set as background, so it’s maybe happening only when you render with the background map being visible in the top area of the image.
Hope this helps.
ok, looks like 3dsmax issue.
Actually, upon closer inspection, this is caused by 3dsmax filtering. I can work around it, so now it should not happen for bitmaps with blur set to 1 or lower.
