1)…
2)alpha(.tiff format) channel does not work properly in opacity map
opacity:
what if you “invert” the tiff in Max?
nothing.the same.
Customize → customize user unterface → quads → reset.
Have you installed any of the pre-A7 daily builds/EUE build? THere was an error in one of them causing this.
ok,but it’s coming back.
I have not permission for daily builds.only official alpha’s A6,A7…
for now you can delete file 3ds max xxxx/scripts/startup/CoronaProxyExporterStartup.ms. I will investigate more what could be causing it.
I have this too. Ive only installed the legit builds, no dailies, Im not entitled.
I have same issue i was about to post it yesterday itself.. A7 release as i have no access to daily.. Proxy shows up 10X times in Quad Menu..
