can I render “old” scenes in 1.0 without differencies / brightness / whatever ?
is old to new Corona compartible or do I need to splite between both versions
thx
thx
Some features have changed so there will probably be differences between scenes rendered with older versions and directly loaded into 1.0 and rendered.
-exposure was reworked (may be needed to manually enable something)
-normal maps may load differently
-reflection model has changed (though this should be preserved when loading an older scene)
how long will a7.2 work btw? and can we revert back for the moment? i have tons of hangs and quirks with the new version and an old scene that needs to be finished in the next few days…
Today is the last day when A7.2 works, i’m affraid. Maybe try to revert to A6, if you have to.
I guess we will manage with 1.0, better to look forward. Especially as we already ordered our licences. The one project which makes troubles will be over anyway in a few days, and it is not the most important one for us. Plus it makes trouble regardless which corona or max version we use, so be it. ![]()
