AA tips
hello there!
I am a new corona user (but with 10+ years of experience in vray)
and although I am really happy with corona’s results , speed etc
I am getting a bit smooth results and I was wondering if the AA default settings
aren’t enough or something …
I surely can fix the ‘‘sharpen issue’’ in photoshop but I would like to see what corona can achieve too !
I am guessing that if I decrease the texture’s blurring from material editor I will have some sharper images
but I would love to hear some other tips !
thanks in advance
Using the corona Sharpen tool in VF’b can be blunt but effective way to get your results.
thanks Tanakov for the reply !
the VFB sharpening is only available in 1.6 version ?
I am using 1.5
Just install 1.6.1 :wink: and also you can try all image filters with values from 1 ~ 3.
If you want sharper details in textures and objects which are in far distance, you need to increase total number of passes. e.g. if you increase passes from 100 - 400 it also increase render time…so you need to decrease 4times GI vs. AA balance. You will get approximately same RT, same GI quality, but better AA.
If you are able try upgrading, it speeds up the process and its tottaly worth it for other features.
thank you very much for the replies !!!
cheers
Lef
