so i had to upgrade the multiscatter to make it work with corona
it gives error msg when you press render ( one for every multiscatter object ) but after that it works fine
i scattered some grass blades like their igrass photo for reference
some fireflies
pts - 8
hd - 1500
left it overnight
478 passes
sun + sky
grass material usual
diffuse + darkerversion of diffuse in translucency
and a 2k ground texture
Can you tell me what version of multiscatter you are using…and also whether you are using Alpha5? I presume I just have to update my version of multiscatter for it to work in A5?
when you press render it will give you error msg saying renderer not compatible and blah blah just press ok and it starts rendering
it’s not a big deal but annoying if you have several multiscatter items coz it gives warning for each one
Thanks for getting back on this. I’m in the process of updating my multiscatter… Keymaster, just wondering what version update multisacatter will work without the warning. Also, does the same aply with IToo forest pack? If you have the build version that works it would be great to know that too.
Thanks guys
