Ugh. Every time I make an export of a movie I do it in 2 steps:
1) Export from Adobe to MOV with lossless PNG compression
2) Open that movie in QT and export it using H264 compression, since QT does a MUCH better job with H264 than Adobe.
On the plus-side, I guess I’ll be cranking out movies a bit quicker. On the minus-side, my movies will be 2-5 times larger. Unless maybe there’s some software out there that can replace this process?
And there was a Windows bulletin saying that QuickTime should be removed from Windows. Apple also said that QuickTime will no longer be supported by Apple.
Problem is nearly every vfx and films studio wants dnx hd quicktimes. There’s a tonne of bullshit with quicktimes internal colour space too, especially with h264. When after effects writes out your comp to a movie, it does it’s own sneaky colour correction on it before it hits the quicktime encoder to try and roughly match apple’s look. I’d love if it died as a format!
