this scene even after over 100 passes still shows green caustics in the circled red areas the screenshot is with only 4 passes for time sake but if you let it run past 100 passes still shows green indirect light from the refraction while by trying to get accurate dispersion pool caustics please fix this for the next daily build thank you: scene download: https://drive.google.com/file/d/18vokP2tgcj2y33c78ulNzY4vTsRLJbbu/view?usp=sharing
Sorry for the late reply. Are you still facing the same issue with Corona 9 HF 1?
