I nearly never need the Vray Message window, but in 3dsMax (and Maya, too) it is always steeling place on the screen.
So it would be great to be able to hide it like every other window, without having it to pop up again and again.
If you hide it, it pops up very soon, when you collapse it, it’s also not nice.
It makes even more trouble with mixed displays (4k and 27"), because the menu items do not work for autodesk, when you use both screens (known problem), so you are forced to put it on the smaller main monitor.
I know also other people have dicussed that “annoying issue”, and tried tricks in Maya, how it could be hidden with nesting into other panels. But this does not ork in Max and is also no good solution.
