Enscape works very well for creating guidance documents, manuals, and training material.
One recurring challenge, however, is the ability to visually highlight specific components by changing their color or transparency directly in Enscape.
At the moment, marking selected parts in different colors or making them transparent can be time-consuming, especially when the geometry is imported from external sources (for example STEP files converted to Revit families).
It would be very useful to have an option in Enscape to:
- Override color for selected components
- Adjust transparency independently of the original Revit material
- Apply these overrides temporarily for visualization purposes only, without modifying the Revit model
This functionality would significantly improve workflows for:
- step-by-step installation guides
- method statements
- safety and training illustrations
At present, achieving this requires workarounds and additional model changes, which slows down documentation work.
Submitted on AHA Ideas (ENSCAPE-I-1760).
Hey Mats,
I guess you are using Revit Graphics Overrides in the Enscape visualization right? If yes, would you please elaborate on the time taking workaround process a bit more? What exactly is time consuming for you, so that we can see if we can improve that or not.
Because implementing a similar flow within Enscape renderer itself (instead of Revit’s own graphics overrides) would require a high amount of invesment.
Submitted on AHA Ideas.
Yes, that’s correct — I am currently using Autodesk Revit Graphics Overrides (view filters, transparency and color overrides) to control how elements are visualized in Enscape.
The time-consuming part of this workaround is not the overrides themselves, but the preparation required to make individual components controllable at that level.
In practice, a single logical component often consists of multiple nested families (sometimes 4–5 levels deep). To visually highlight just one physical part for manuals or step-by-step instructions, I currently have to duplicate and modify entire family hierarchies or adjust materials purely for visualization purposes.
This becomes even more time-intensive when dealing with imported geometry (e.g. STEP/DWG), where the geometry must be decomposed and partially rebuilt simply to gain per-part visual control.
I am currently exploring an alternative approach based on per-instance shared parameters combined with Revit view filters. However, this depends on potential changes to our Revit template maintained by a third-party developer (NTI / Scaffoldplanner), and I have not yet been able to validate whether this approach will sufficiently solve the problem in practice.
Even if this approach proves viable, it still requires modifying BIM content and templates to achieve what is essentially a temporary visual state. From my perspective, this suggests that this workflow should exist at the visualization layer rather than at the BIM layer.
Submitted on AHA Ideas by Mats Jektvik.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
