So basically you want a fast updating scene, while you search for a good camera angle, then when you find a good view, you want let it render fully
So how about using the test resolution setting in the VFB, to create a lower res interactive render 10%, 25%, 50% or 75%, until you find a good camera angle, then switch them off and render the scene
I’ve found this incredibly useful
BUT you were asking for some way to pause the IPR, freeze the updating in the VFB, while making quick updates (especially in large scenes) but sadly that would never work, if you pause the IPR to prevent it updating, then move the camera, how do you know what it is going to look like (isn’t this the idea of the IPR), until you resume the IPR. If you could pause the IPR in that way, and then moved the camera, it would still take just as much time to redo the render, as it would when moving and watching it update the render interactively
Give the test resolution buttons a try OR maybe try turning on Fit resolution to VFB in the IPR options section, that way you can resize the VFB window and the resolution of the render sizes to fit and the smaller you go, the faster the interactivity
OR if you have the budget of course, you could just upgrade your GPU, get an RTX card and see just how fast the IPR can be.
I have seen many requests to prevent the IPR from updating for simple things like changing the colour of a material of just moving an object, even when just opening the material editor, it will refresh, but as I say, that’s the whole idea of the IPR Interactive, Progressive Rendering. Pausing it, is basically the same and stopping it, making a few changes and hitting “Start IPR”. I t canot possible be pausd as you request, allowing you to move the camera and then continue, it has to refresh the entire scene
Oh and how about “Smart IPR”, that only updates the areas of the scene that you are making changes to. For instances, you what to change the material of a chair in an interior scene, you open the material editor, change that one material and the IPR only refreshes that part of the render, similar to rendering a single object, or material, which is indeed possible. You move the camera however and of course, it has to refresh the entire scene, you move an object, it has to refresh every part of the scene, from where it was originally to where you move it to, plus all the spaces in between, that the object covered while being moved.. That would be incredible, but the kind of programming required to make it a reality, would be beyond genius level.
