Ability to use more than 64 threads
*Double post
TUrning off HT would typically reduce performance by 20-25%, so thats really not an option …
Does anyone know how v-ray handles 2x 12 cores (48 threads) or 2x 16 cores (64 threads) on a single machine? We may go that route.
2x12 cores is not a problem at all. It scales very close to 100%. Just make sure all the memory settings are optimal and reduce the bucket size. I found that a bucket size of around 10 (+\-) is optimal for 48 threads.
What is the rhyme/reason behind picking a specific bucket size or is it purely experimental on what works best per scene? Are small buckets to keep the L1-4 fetches to RAM consolidated so that all cores are working on similar data and each core’s cache isn’t requesting totally different data and bottlenecking the RAM pipe?
I don’t think it has anything to do with RAM caches, but more with CPU load balancing.
reduced the bucket size from 64 to 12 on my 48 thread machine… adds ~50% rendertime… ?
Its just experimenting for the specific scene, but for 48 threads its generally around size 10. Vlado kan probably elaborate on why :slight_smile:
All I can say is that by reducing the bucket size, things generally renders faster. If I use a low core \ high frequency machine of the same CPU-architecture as a bar for 100% theoretical performance, I get very close to optimal performance on a 48 thread machine
Anyone that wants to test a build with support for processor groups, please email me to vlado@chaosgroup.com with your 3ds Max version number so that I can get you download links.
Vlado,
“64+ threads support – Corona Renderer now correctly works with more than 64 threads without any workarounds”
http://cgpress.org/archives/corona-renderer-1-3-for-3ds-max-released-future-developments-announced.html
I understand all the implications you mentioned earlier in this thread, and that its possible to get a build with 64+ threads enabled. But maybe its time to at least have a switch for this somewhere in the official build? :slight_smile:
I did post above that anyone interested in a build can email me to vlado@chaosgroup.com
But maybe its time to at least have a switch for this somewhere in the official build?There is a switch for the next official build coming out in December and it may even be enabled by default, depending on what the beta testing shows.
Very nice :slight_smile:
and does the new version also adress the issues with Multiscatter on a machine with multi processor groups (more then 64 processors)?
Wouldn’t that be a question for the Multiscatter guys?
nope, you , Vlado, already confirmed that this is a Vray problem, has to do with Embree library version… so any date on updating embree library?
We are working on it. We’ve done a lot of custom modifications to Embree, so updating it is a complicated process. I will be able to tell you more in about two weeks, if all goes well.
great great great, really great :slight_smile:
Hi Vlado,
Any news sofar?
We tested the new vray (35501) and stil much slower compared to rendering with vrayspawner
Well, this moves a lot slower than I would have liked, unfortunately :confused: My goal is to have beta 2 released with Embree 2.12 and see how that goes.
