I’ve run into a very bizzarre rendering behaviour with one of our workfiles. I’m getting this jump in a camera in random places. Here’s what we’ve debugged with RANCHComputing so far:
Try #1: Rendered range 1482 - 1666 the jump occurs at frame 1490.
Try #2: Rendered range 1162 - 1709 the jump occurs at frame 1328.
Debugging the first try:
Time Output with Single frame at frame 1490: OK (renders like the active viewport).
Range with frame 1490 (1490 to 1490) AND timeline cursor at 1490: OK (renders like the active viewport).
Range with frame 1490 (1490 to 1490) AND timeline cursor at 0: NOT OK (the rendered camera differs from the viewport as if either camera position has changed or the lens is zoomed just a bit).
Can you send us that scene for investigation?
Have you tried to render the scene with another render engine in order to identify if it is a general 3dsMax issue?
Good call. Replicated with MR so definitely an Autodesk issue. Thank you for the fast feedback on this. I will contact Autodesk support for additional debugging.
By every release, I’m more amazed how they can generate so much bugs on software’s core functionalities. Sounds very Autodeskish again. Thanks for the info!
Do you use the legacy vray cam? I’ve had lots of issues with the max physical cam but I thought it was just me getting used to it and chalked it up to user error.
