Hello. There was a problem with the render. During rendering save all passes and throws an error (see. Picture) Save only beauty pass. After repeated attempts max throws. I noticed that mostly happens when you add passes. The problem is not in the scene, since such other computer was not observed. 3d ma2014 | Corona render 1.1.1
Have you tried with newer versions of Corona?
Can you share your scene? Or recreate this in another one? Or write step-by-step what you are doing?
