I don’t know yet which renderer i’m going to use for my work (MR, Final render or Vray)
I have some concerns about the dongle thing, do you need the dongle only for the installation or you need it pluged each time you use vray ? what if i want vray installed at home and at work, do i have to bring the dongle each morning and leave the office with it to be able to use vray at home ?
This gets me a lot. I usually work from the office and from home and when I forget the dongle I am stuck. When I forget the dongle in one place or the other I end up logging in remotely to the machine that has the dongle. Since I am running xp64 I don’t have a driver for my routers VNC app. If I did I could use the office machine as a license server and it wouldn’t matter.
V-Ray is well worth this little hassle for me anyway! I’ll probably purchase another dongle anyway, just in case.
So it’s possible to get a second dongle for the same license from your reseller ? it could be a solution, one at home and one at the office, withtout the need to buy two licenses of course.
Yeah I take my dongle home with me and export the Max license for use at home for the night, unless i’m doing a render or whatever. I have a zip pocket in my jacket, it’s called the VRay pocket. I guard it with my life.
You can also set up a licenseserver over http with the dongle. That way you could leave it at the office and grab the license from home. Or set up a VPN and grab it via the VPN.
