When we have a mesh light, with its material assigned, we should hope that when we “turn off” the light leaving the lumens to 0 vray reveals the material assigned to the lighting mesh, like if mesh was “incandescent or radiance”? Because the real result is simply black, without any material revelation.
Is this the correct behaviour, or this is still for change?
Why? if a bulb doesn’t emits any radiation (0 lumens), it reveal its aspect (VrayMaterials). Why do you want leave the mesh completly black overriding the material assigned?
Ok then. So if we want render a bulb turning off, we need use BlendMtl material with VrayLightMaterial in the Coat, and the white crystal like base material, right?
And respect the radiance (incandescence) itself… how if we need a correct radiance from the mesh?. Using two meshes, one with vray light mesh and another with blendMtl in the same place, will give us render errors for interpolation between two meshes. The system is designed for do it in two passes, and mix it in compositing?.
