Hi everyone, I need help immediatly. Thank you for your reply in advance.
When I render a pink object in the room that have white walls, all walls seems pink. Is there any way to turn off to pink reflection ? My metarial’s reflection and refraction amount is 0 but result is still same .
That’s not reflection (in the CG sense), that’s bounced light, called GI. Light bounces off all objects, picking up the color from the object it bounces from - it’s how you see the objects after all
This is physically correct.
Anyway, if you want to control the effect artistically, you can use a RaySwitch to fake it https://coronarenderer.freshdesk.com/support/solutions/articles/5000529341-what-is-rayswitch-material-and-map-
