As for the in-depth study of the channel map, Enscape provides a professional material channel map adjustment, and the final result is very satisfactory. The model is a simple model of the plane. Through the mapping and adding a variety of concave and convex, reflecting the map of the channel, it has achieved the effect of the photo level.
Beautiful!! Thanks for sharing. Looks very realisticly!
how did you incorporate the water on the last one..?
Technically, it’s just a lower roughness as @tas_1985 already explained with his reflective map. Be sure to keep metallicness at zero, else it looks like mercury.
That water reflection is :thumbup: :thumbup:
Professional performance
I wonder when we can use displacement map channel in ENSCAPE
@rockingbird , filed your question in our internal discussion
Today I tried to replicate the water reflection effect by adding white spots to the roughness texture. However this did not work. I have also tried black and transparent spots which did not work either
Am I missing something?
Thought the same… in revit, but it seems that I used wrong map slot…
Impressive work @tas_1985 !
May I ask where you get / buy those high quality textures?
Jorgensen
Ah thanks - sould have figured it out when seeing the name of your texture ![]()
thanks
Jorgensen
