About the Vantage timeline
hello,
I created an animation in 3dmax with a timeline range of 0-50 frames. The correct sequence should be short1_0000.0001.0002…0050, a total of 51 sequences of images.
However, when I import Vantage, rendering at the same frame rate will only yield short1_0001.0002…0050, a total of 50 sequence images, I don’t know which frame is missing.
Now Vantage can only support moving, rotating, zooming animations. There is no support for parameter animations such as light brightness, color changes…, so I had to export a lot of Vrsence separately, but rendering the resulting frames would cause a lot of trouble.
Or when I pause and close Vantage, and open Vantage again and I’m going to go back to the last render sequence file, and I don’t know which frame to start with,Is there a solution?
