About UI for loading LUT
The current loading method is not so convenient when I cycle to test which LUT file is more appropriate
It blocks the screen
Hi q976431,
Thank you for the feedback, I will log in your request and we will try to improve it.
Alexander
If you want to compare a few files from a large directory like this, you could first load each LUT using the “Load LUT file” button and dialog and then they would all be at the top of the recent list and you can switch between them by hovering.
yes. But when there are too many LUTS in the folder. It will block a large part of the picture
I may not need to test specific LUTS.
I hope to find the most suitable effect by randomly sliding the LUT in the folder.
Obviously, when the current UI method contains a lot of LUTS in the folder, it will block the screen.
It might be better to turn it into a drop-down list of scroll bars
