Absinthe Mystique
As a 3D artist, I’m excited to share my latest artwork, titled “Absinthe Mystique,” rendered in Corona Render! I used a Polyhaven HDRI map to achieve stunning results — candlelight, absinthe taking center stage, and a natural atmosphere all come together beautifully. Share your thoughts!
Very nice, but here is what immediately caught my eye:
  • the bumps on the chalice are very low-poly - (here)
  • some of the berries are floating - (here)
Thank you for your feedback. The model is a megascan based on an existing scanned model, which explains the low-poly appearance of the bumps. Regarding the floating berries, I’ve checked the scene, and they are placed on the surface, but the contact points may not be clearly visible due to the high lighting in the background. I appreciate your observations!
Good job :clap::+1:
thanks so much my bro <3
Good job :+1:
“If it’s not too much trouble, may I ask for your advice? Your lighting technique is exceptional. Could you share some tips?”
Very cool, my brother <3
tornike- I’d like to say that the key is to achieve the desired composition of light and shadow, and then the materials should be processed in relation to that lighting.
gogita – thanks so much my friend
