Absorption Color in Corona Layered Material
I ran into an issue where 2 corona materials with absorption color within a corona layered material isn’t rendering properly. I’m using a mask inside the layered material to define the 2 separate colored glass materials and only the one plugged into the base material slot will render. Is this a known bug? Thanks
Yes, it is known bug/limitation. Workaround would be to use single Corona material and plug mix node into absorption slot and checker into mix’s mask slot.
Thanks for the tip!
I was aware about the bug with absorption color and multi/sub-object materials but didn’t know it applied to corona layered materials as well.
