Can we have the people as meshes if we need, sometimes I have to sculpt details like moving fabrics for seated people, remove phones, or move hands etc … I can only do this with the chaos cosmos people and it is pretty annoying if a character is almost perfect but can’t be used because of a minor detail.
I asked tech support this question and didn’t even get a reply.
I need them for a LED volume project where they can’t use the Anima plugin.
Anima is an absolute pile of shit that is about to fuck itself out of the market.
Love that comment, hey chaos WAKE UP!
still no answer…
No, it is not possible to modify the meshes from the Anima content. This limitation is already mentioned in the Chaos Help Center, in the following article:
And also in the Anima documentation, here:
This limitation is required because we need the plugin to verify the ownership of the content, and providing direct access to the meshes would break the connection to the plugin.
Thank you Albert,
I knew why it’s happening and the delays the DRM is causing to us, but is there any way to have a DRM protected editable poly? Or just being able to edit and save in anima drop as variations of an asset. I think this could be a great feature for us.
Good Morning @ALEX_SPYROPOULOS
We agree, having this feature would be very useful on many advanced use cases like the ones you are describing. Unfortunately, we have not found a way to allow this possibility and, at the same time, keep the security on the assets.
