Access scatter instances positions as scene objects without converting
When scattering high resolution proxies its often the case that in order to use those objects to drive other scatters we need to use a distance map to generate a map for scatters.
This is extremely inefficient because of the way the distance map works but also because it seems like the proxies need to be loaded into memory for the distance map to calculate.
To resolve this issue, primitives can be used in place of the scatters, arranged via ‘clone and align’ but in order to do this, the scatter must be converted to max geometry losing its procedural nature.
It would be great if there was a way to let users decide whether a scatter should be accessible as separate scene objects in the scene explorer or not. Perhaps they get listed as children of the scatter object if a checkbox is enabled. They shouldnt necessarily be editable, only selectable.
An alternative would be a way to let users scatter dummy objects or point markers in the exact same place as the scattered geometry for this purpose.
An example use case would be scattering proxy trees, using a distance map to then scatter debris and other plants around only the bases of the trees. Currently using proxies in a distance map is very very slow. Placing cylinders in place of the proxy trees resolves the speed issues instantly.
Submitted on AHA Ideas (SCATTER-I-17).
Hi just to clarify:
Would you like to distribute instances from one scatter over another Scatter by using the second Scatter as a base object?
Or you would like to stick the instances of one Scatter close to another Scatter like a magnet but still respecting a common surface between the 2 Scatters? More like, wherever I have a tree, I want to have bushes near it. The tree is one Scatter, the bushes are another Scatter, and both of them are applied on the same surface.
Submitted on AHA Ideas.
Hi, just a reminder on the questions above. Thanks
Hi, Apologies im on a different login but It would be the latter. Scattering close to another object. In this instance i was using scattered trees to create a distance map on a surface and then using that distance map to scatter other shrubs around the tree bases.
Great, thank you for the clarification.
That’s pretty much achievable already. All you have to do is to make a copy of the scatter object, remove all the high-poly objects from scattered instances list and add your dummy object there. As long as you keep scattering parameters like seed, transformation settings, etc the same between the two scatters, they will scatter the instances at exactly the same places. I think the only exception would be avoid collision parameter - you would have to ensure that your high-poly and dummy objects have exactly the same bounding boxes if you want this to work.
By the way, if you’re Max user, you can quite easily link parameters of the two scatters and they should stay in sync automatically.
Submitted on AHA Ideas by Vardenis Pavardenis.
