I have recently started to test some animation. As you know animation testing is not that fast so I figured it won’t be bad to ask for some advice to speed up the process.
This video is rendered at 29.97 fps, and it feels a little jagged especially the right side of the building in the foreground.
I used PT+UHD (precomputed)
GIvsAA : 16
LSM: 2
Animation (flicker-free) precision 1.0
Do you mean the movement of the camera being a bit “jagged” or some jagged edges/flickering?
There was a discussion about fps some time ago on the forum, and it is best to use the multiplication of some standard monitor refresh rates, so for example 30fps: https://forum.corona-renderer.com/Recent Spaces - Cameron Design House - Parts I and II#msg110385
30fps seems to help a bit and I will also try the motion blur suggestion form that thread.
I feel the edge in the attached screenshot is a bit shaky in particular. Might be normal due to the lack of motion blur, high contrast and relatively fast camera movement?
Is there any way to smooth this even more in AE for example?
Do you have both bloom and glare enabled? I wonder if it could be the glare streaks pattern dancing around. Is it the same with B&G completely disabled?
Not familiar with twixtor but here is a comparison with left: ReelSmart motion blur (standard version as AE plugin) with the original 30fps and right: standard AE pixel motion frame blending 30 to 60fps (the mpg is 60fps but the left side has double frames to be able to put it in one video).
@maru I’ll have to test without the BG to see. @romullus I’ve never used twixtor, I am even new to AE to be honest, but from what I’ve seen on YT looks good, @Frood the right side looks great actually i need to try it myself
Unfortunately it is very scene/frame dependend. If there would be strong horizontal lines in this example, the algo would fail and produce artifacts. So it’s no fire-and-forget solution :-/
@Frood can you explain the process to get the result on the right. I tried to time remap it with motion frame blending pixel motion on, but I can’t get that result. I am sure I am missing something.
I’ve just put your 30fps footage into a 60fps composition. The image frame should change only every 2 composition frames now (check with pgup/pgdown). Then I activated pixel motion frame blending on the layer (RMB → Frame blending → pixel motion, or Icon). If the content still changes only every 2nd frame you may have not activated the compositions frame blending icon? See screenshot.
Looks to me like some analysing radius is visible here. But nevermind, you will get enough surprises like this with AE pixel motion frame blending as well.
@Romullus: I see such distortions immediately because I hate them so much. On the other side there are enough “Woah, see how this looks badly”-posts where I just have to shrug
