Achieving Specular Highlights Indoors with natural lighting
Have always been frustrated by not having Specular Highlights Indoors using the Vray SUN/SKY/PHYSCAM setup to get a very natural lighting.
Specular Highlights only work when the first reflective bounce is hitting a direct light. Often most of a scene indoors is not in direct light so you don’t get any specular highlight render element layer for doing quick & easy [& more realistic] highlight glows in post-production.
See below for an image of the scene setup to achieve specular highlights indoors.
Simply put a vray light in the window and check ‘SKYLIGHT PORTAL’
The GI - lighting from this light will be exactly as the Vray Sky behind it [Something I think that would be impossible to just GUESS??? which now seems obvious why this option was implimented]
You should now have nice speculars indoors!!
Cheers
Cool, thanks for the trick!
whats the difference in render times between the two?
I haven’t had a chance to compare render times yet, [I was only testing the quality so far] although with the small test scene I used didn’t seem to add any extra render time.
I will test again soon when time permits
cheers
